Synergy E6/7 Torque Tube Kit Released!
  • Synergy E6/7 Torque Tube Kit Released!
    Just a heads up to let everybody that has been waiting for a Torque Tube Version of the E6/7, a Torque Tube E6/7 Kit has now been released and should be available soon!
    The kit is essentially the same as the belt drive version and includes all components to build as either and E6 or E7.
    E6/7 Torque Tube Kit – Released!
    Now featuring unparalleled Mod 1.25 Tail Transmission -
    Mod 1.25 machined Delrin bevel and spur gears are super silent while providing high durability for today’s 3D pilot.
    Precision Machined Helical Main Gear-
    Smooth running Mod 1 custom machined helical gear is stealthy silent and provides plenty of girth for today’s high powered electric motors. Settling for a molded main gear on a high powered electric was just not an option.
    Third Bearing Block Main Shaft Support-
    The main shaft has third bearing block support to ensure proper gear mesh and eliminate frame flexing during hard 3D maneuvers.
    Motor Shaft Pinion Support-
    The E6 pinion is supported by a lower bearing block which also ensures a proper gear mesh.
    Carbon Servo Arms-
    Custom carbon servo arms for the ultimate precision in flight.
    Features:
    • Precision machined helical main gear
    • Third bearing block support for main shaft
    • Bearing block support for motor pinion
    • Multiple battery configuration options (8s, 10s, 12s)
    • Flybarless head designed specially for ALL of today’s FBL Electronics
    • Extremely light and Ultra rigid carbon fiber frame design for those serious competition pilots
    • Motor mount handles M4x30mm mounting patterns
    • Motors up to 60mm in diameter accepted between frames
    • Accepts rotor blades 600-716
    • Carbon servo arms provide for a much better precision feel in flight
    • 14 and 15 tooth pinions included!
    • Unparalleled Mod 1.25 Shaft Driven Tail Transmission
    Thanks!
    Rossco
    Equipment for Sale:
