Synergy E7 Torque Tube Tested!
  • Synergy E7 Torque Tube Tested!
    Okay so i received my Torque Tube kit yesterday and put it together last night. First impressions was Wow, This TT kit is so compact and such good quality. The rear tail gearbox is perfectly designed and looks amazing! This kit is also so easy to build, its just a case of re loctiting and following the manual carefully. It really doesn't take long to build at all! The build is really straight forward, the only hard things to do were the drilling and thats it.
    So Today was the big day I got to test the TT after waiting a while. I wasn't to happy with the Belt as it did restrict my flying a lot. I took off and did some pirouettes then changed directions and notice it stops and changes a lot quicker! Then started to punch it hard to see if the tail would kick out at all but had no luck with that so was very very pleased. Last thing i tried was reversal piroflips, On the belt this would be a little difficult as there was delay but with the TT there is no delay at all, It changes direction instantly.
    This kit is well worth the money and would highly recommend it to all E6/7 users as it is a must have and makes the heli look a lot nicer as well as makes the heli fly a lot better.
    Here are some pictures of the build and a quick video from today
    IMAG0323.jpgIMAG0327.jpgIMAG0328.jpgIMAG0329.jpgIMAG0330.jpgIMAG0331.jpgIMAG0332.jpgIMAG0333.jpgIMAG0335.jpgIMAG0337.jpgIMAG0338.jpgIMAG0339.jpgIMAG0340.jpg
    Synergy E7 Torque Tube Test - YouTube
    Adam Melton
    Synergy E7 : BeastX V3, Scorpion hk4525-520 LE, outrage HV servos
    ELYQ vision 90 : BeastX V3,YS91 3DS,Outrage HV servos
    Rave ENV: Vbar silver line, outrage HV servos, os105, hatori exhaust
    Trex 450 pro : Spartan quark, MKS ds95, scorpion hk 2221-6, 11t pinion
    Blade 130x !!
    Futaba 8fg
    Spin Blades / Rail blades
    Sponsored by
    Good to see your enjoying the Torque Tube Adam!
    Thanks!
    Rossco
    Equipment for Sale:
      Nice piece of kit! I am glad you are happy with it Adam, great flight too!
      Michal
        drilling?
          Originally posted by debrooker View Post
          drilling?
          The Torque Tube Conversion gives you the option to Pin the tail boom assembly front and back for extra security.
          Thanks!
          Rossco
          Equipment for Sale:
            drilling?
            As ROSSCO said. You can pin the boom at the front clamp and you have to pin the tail gear box on along with a clamp
            Adam Melton
            Blade 130x !!
            Futaba 8fg
            Sponsored by
              Adam, glad to hear you are enjoying your new Torque Tube! Great pics and video, thanks for sharing
