Synergy E6/7 TT Conversion Kit Released
  • Synergy E6/7 TT Conversion Kit Released
    The release of the E6/7 Torque Tube Conversion Kit is here. The E6/7 TT Conversion Kit Retail Price is £160.00. Grab a kit from your favorite Synergy dealer and enjoy this high quality upgrade! Please be sure to read the manual in its entirety before assembling. The manual is short and sweet but there are some very important information regarding the build that will make your life much easier.
    The Manual for the Conversion Kit can be found here: http://synergyrchelicopters.com/Synergy_E67_TT_Conversion_Manual_v3.3.pdf
    Below is what comes in the TT Conversion kit, it's essentially an entirely new front and rear transmission. The below parts comprise more than 1/3 of the entire helicopter.
    TT Conversion Parts list -
    CF Vert Fin - TT E7 1pce (yes, this conversion requires a new CF vert fin)
    18T Front Trans Bevel Gear 1pce (machined delrin gear)
    18T Front Trans Mushroom Gear 1pce (machined delrin gear)
    20T Bevel Gear - E7 1pce (machined delrin gear)
    20T Bevel Mushroom Gear - E7 1pce (machined delrin gear)
    12T Spur Gear 1pce (CNC hard coat aluminum gear)
    54T Spur Gear 1pce (machined delrin gear)
    TranSupport Standoff 6pcs
    Front Mushroom Gear Bearing Block 1pce
    Bevel Gear Top Bearing Block 1pce
    Spur Gear Bottom Bearing Block 1pce
    Tail Box 1pcs
    Tail Box Plate Left 1pce
    Tail Box Plate Right 1pce
    Tail Box Plate Spacer 1pce
    Output Shaft Spacer 1pce
    Tail Box Bearing Spacer 1pce
    2mm Bevel Gear Pin 2pcs
    2mm Spur Gear Pin 1pce
    Spur Gear Shaft 1pce
    6mm Tail Output Shaft 1pce (included for those who run bent tail output shafts and dont know it)
    6mm Shim 1pcs
    Tail Bell Crank Mount 1pce
    Spur Gear Hub 1pce (this is a very nice cnc hub to support the 54T Spur Gear)
    Jesus Bolt Collar 1pce
    Torque Tube E7 1pce
    Torque Tube E6 1pce (yes, you get a TT for your E6 if this is the way you decided to build the kit)
    Torque Tube End 2pcs
    Torque Tube Bearing Housing 2pcs
    O-Ring 4pcs
    6x13x5 Radial Bearing 2pcs
    8x14x4 Radial Bearing 2pcs
    12x18x4 Radial Bearing 4pcs
    5x9x3 Radial Bearing 3pcs
    5x10x4 Radial Bearing 1pce
    M3x6 Set Screw 1pcs
    M3x12 Set Screw 3pcs
    M2x10 Socket Head 2pcs
    M3x6 Type 1 Cross Recess 4pcs
    M3x6 Button Head 27pcs
    M3x8 Button Head 6pcs
    M3x10 Button Head 3pcs
    M3x30 Socket Head 1pcs
    M3x8 Socket Head 1pce
    M2 Regular Nut 2pcs
    M3 Nylock Nut 1pce
    M3 Washer 1pce
    Thanks!
    Rossco
    Equipment for Sale:
    which uk shops have this rossco?
    Troll buster
      I believe these were received by Climb-Out today so dealers my have them tomorrow or Monday.
      I will find out tomorrow and update on stock availability
      Thanks!
      Rossco
      Equipment for Sale:
        Its lucky there arent to many parts for this then!
        Tail Box 1pcs
        6mm Shim 1pcs
        Torque Tube E7 1pce
        O-Ring 4pcs
        M3x6 Set Screw 1pcs
        M2 Regular Nut 2pcs
        M3 Nylock Nut 1pce
        M3 Washer 1pce
        Goblin 700
          Conversion Kit is now in stock!!
          Check it out!! 320-100 Synergy E6/E7 TT Conversion Kit
          Thanks!
          Rossco
          Equipment for Sale:
