Just seen this from Matt himself.
Below is what comes in the TT Conversion kit, it's essentially an entirely new front and rear transmission. The below parts comprise more than 1/3 of the entire helicopter.
TT Conversion Parts list -
CF Vert Fin - TT E7 1pce (yes, this conversion requires a new CF vert fin)
18T Front Trans Bevel Gear 1pce (machined delrin gear)
18T Front Trans Mushroom Gear 1pce (machined delrin gear)
20T Bevel Gear - E7 1pce (machined delrin gear)
20T Bevel Mushroom Gear - E7 1pce (machined delrin gear)
12T Spur Gear 1pce (CNC hard coat aluminum gear)
54T Spur Gear 1pce (machined delrin gear)
TranSupport Standoff 6pcs
Front Mushroom Gear Bearing Block 1pce
Bevel Gear Top Bearing Block 1pce
Spur Gear Bottom Bearing Block 1pce
Tail Box 1pcs
Tail Box Plate Left 1pce
Tail Box Plate Right 1pce
Tail Box Plate Spacer 1pce
Output Shaft Spacer 1pce
Tail Box Bearing Spacer 1pce
2mm Bevel Gear Pin 2pcs
2mm Spur Gear Pin 1pce
Spur Gear Shaft 1pce
6mm Tail Output Shaft 1pce (included for those who run bent tail output shafts and dont know it)
6mm Shim 1pcs
Tail Bell Crank Mount 1pce
Spur Gear Hub 1pce (this is a very nice cnc hub to support the 54T Spur Gear)
Jesus Bolt Collar 1pce
Torque Tube E7 1pce
Torque Tube E6 1pce (yes, you get a TT for your E6 if this is the way you decided to build the kit)
Torque Tube End 2pcs
Torque Tube Bearing Housing 2pcs
O-Ring 4pcs
6x13x5 Radial Bearing 2pcs
8x14x4 Radial Bearing 2pcs
12x18x4 Radial Bearing 4pcs
5x9x3 Radial Bearing 3pcs
5x10x4 Radial Bearing 1pce
M3x6 Set Screw 1pcs
M3x12 Set Screw 3pcs
M2x10 Socket Head 2pcs
M3x6 Type 1 Cross Recess 4pcs
M3x6 Button Head 27pcs
M3x8 Button Head 6pcs
M3x10 Button Head 3pcs
M3x30 Socket Head 1pcs
M3x8 Socket Head 1pce
M2 Regular Nut 2pcs
M3 Nylock Nut 1pce
M3 Washer 1pce
The E6/7 TT Conversion Kit Retail Price is $199.00. Dealers and distributors will not be happy because I had to remove all of the margin in order to keep you, the customer, happy with the final price.
Release date - The CNC shop is trying to ship TT Conversion Kits next week 4/9 - 4/13. I will keep you posted as to whether that happens or not. I know the wait has been long but the drive system is right and I think you will be happy with it.
Let me know if you have any questions!
Thanks,
Matt
Tail Box 1pcs
6mm Shim 1pcs
Torque Tube E7 1pce
O-Ring 4pcs
M3x6 Set Screw 1pcs
M2 Regular Nut 2pcs
M3 Nylock Nut 1pce
M3 Washer 1pce
Thanks,
Matt
