Post what set up your gonna run E6/7
  • Post what set up your gonna run E6/7
    Just ordered a E6/7 and gonna run it as a E7, below is what iam gonna run what do you think?
    My only concern is the motor, whether its the correct one?
    Blades--- Radix Flybarless 690's & Rdaix 105 tails
    Cyclic servo's--- JR DS8911 X 3
    Tail servo--- JR DS8900G
    FBL Controller--- Mini V-Bar v5.2
    Speed controller---Kontronik Heli Jive 120HV with heatsink
    Motor---Scorpian Motor 4525-520 Limited Edition
    Batteries--- 12s 4500mah
    What are your choices on your set up and views on the power set ups?
    Troll buster
    People have been using the hacker turnado in the e6
    Chris 'CHUNK' Newby
    ALIGN-TREX.CO.UK team pilot
    LYNX team pilot
    SPARTAN team pilot
    Dx18
      Problem is i already have this motor and not using it, so rather than it going to waste i thought i would try and use it.
      Troll buster
        Think that motor not fit Ross but I'm not sure. Check on the freak as they were talking about this subject.
        If I do order one I got all the gear on the bench.
        Kontronik's esc and motor, bls servo all round, vbar mini or full depending on mounting locations and radix Fbl blades.
          Ben when you say wont fit do you mean the size wont fit or the motor is to powerful?
          Troll buster
            Size mate.
              Run as an E7:
              Outrage servos all round
              Scorpion motor not sure which one yet
              Kontronik esc or scorpion esc
              Spinblades
              Adam Melton
              Synergy E7 : BeastX V3, Scorpion hk4525-520 LE, outrage HV servos
              ELYQ vision 90 : BeastX V3,YS91 3DS,Outrage HV servos
              Rave ENV: Vbar silver line, outrage HV servos, os105, hatori exhaust
              Trex 450 pro : Spartan quark, MKS ds95, scorpion hk 2221-6, 11t pinion
              Blade 130x !!
              Futaba 8fg
              Spin Blades / Rail blades
              Sponsored by
                I recon the KV of that motor is to high for the stock pinions and do not think the 12 or 13 tooth ones are available yet, the hacker I think is being used is the A50-12L Turnado that is a 470Kv motor.
                  If it does fit between the frames, but im not sure it will? with one of the upgrade pinions 12 or 13 tooth I recon you would be fine with that motor just put info into mr mels head speed calculator v3 and got this.
                  with 14 tooth pinion and jazz/jive esc programed in mode 4
                  65% throttle 2377 rpm
                  72% throttle 2521 rpm
                  85% throttle 2665 rpm
                  with 12 tooth pinion
                  65% 2037 rpm
                  75% 2521 rpm
                  85% 2665 rpm
                  this was if useing 35c lipos.
                    Sorry ment on 12 tooth
                    65% 2037rpm
                    75% 2160rpm
                    85% 2284rpm
                      Think this is the link to the headspeed thing
                      http://rc.runryder.com/helicopter/ga...ript=headspeed
                      Cheers Paul
                      Citizen #42
                        Yes thats the one Paul, the synergy e6/7 main gear is already in the list of main gears.
                          Currently flying pre-production kit:
                          Configuration: E6
                          FBL System: Futaba CGY750
                          Motor: Hacker Turnado 580kv
                          Pinion: 15T
                          Target Headspeed(s): 2000/2300
                          ESC: Castle Creations ICE2 HV120
                          Governor: Castle ICE
                          BEC: Flighttech 8a Regualtor @ 6V
                          RX Pack: Optipower 2150 2S 7.4V
                          Cyclic Servos: Futaba BLS451
                          Tail Servo: Futaba BLS251
                          Main Blades: Rail 606
                          Tail Blades: Rail 96
                          Lipos: 2x Optipower 5S 4300mAh (10S)
                          Thanks!
                          Rossco
                          Equipment for Sale:
