RJX crrc gasser now pulling my hair out ahhhhhhhhh
  • RJX crrc gasser now pulling my hair out ahhhhhhhhh
    So a quick update on my CRRC gasser; I am no further forward infact i am ready to smash the thing to bits.
    After spending hours trying to get this thing started after doing the following.
    Replaced: spark plug
    cdi unit
    piston ring
    gaskets
    ign pick up
    Removed carb cleaned and replaced gaskets
    Reset ignition timming to 28 BTDC allso tried TDC
    I have made myself a jig and an adapter to start straight from the fan using a 24v drill so it is getting a real good spin over.
    All I seem to get is a bit of a pop out of the exhaust.
    Any help or advice would be appreciated.
    Ian
    Hang in there Ian - we need a gasser down at the patch. Looking forward to seeing you tick-tock it!
    Mike
    Trex 700 DFC - Vortexted, TRex 600, OUTRAGE FUSION 50, 500ESP, 450PRO, 130x.
      can u give me more info on the engine model etc ?
      Century Robinson R22 (waiting engine replacement)(job 2)
      Align T-rex 500 (in service)
      Align T-rex 450 pro v1 (in service)
      Hirobo Lama (awaiting overhaul)(job 3)
      Align T-rex 600n pro (in service)
      Align T-rex 700n pro (being over hauled)(job 1)
        Tick tock, It will fly one way or the other trust me.
        Ian
          rjx crrc basicly a clone of crrcpro gasser yea ?
            Hi,yes it's a crrc 26cc thats all I know!!!!!
            CHEERS
              http://www.crrcpro.com/product_show.asp?id=231
              a
              nything like this ?
                Sounds like a fuel issue.
                Is the carb back to default needle settings?
                Blade mCPX - now Version 2
                  HI yes thats the one
                    found this info might be handy
                    I have a carb "Walbro WT 809 668B".Low screw : open 1 tHigh screw : open 3/4 tBattery : nicad 4,8V 2500mAhOil : 2,5 %In the carb, the metering spring should be checked: 0,6 to 0,8 Bar pressure to release the metering lever."
                      also have u got manual for the engine ?
                        hi yes i have tried back to default then moved them both ways from there.
                        Ian
                          i take it when u repaced cdi u had to replace sensor too ?
                            OK so if the low needle is as per the book and the engine does fire (by the 'pop' that you are getting when you crank it over) what happens if the throttle trim is increased to let more fuel into the engine?
                            The butterfly valve's not shut down too much at idle is it?
                              Hi i have moved the throttle position from open to closed it seems to fire more at about 1/4 open.
                              thanks
                              ian
