New RJX X-Tron 500 FBL helicopter is now In Stock
  • New RJX X-Tron 500 FBL helicopter is now In Stock
    Just arrived is the Newest model from RJX, The X-tron 500 FBL, this is their version of the ever popular 500 electric class helicopter.
    For the moment it arrives as a 'plain kit' so allowing the builder the selection of motor esc and main blades and radio gear, a Scorpion type 1400-1600kv motor with approx 60-80 A esc required. It arrives with full carbon side frames with sliding lipo tray and carbon & alloy U/C, full alloy head and tail which is belt drive. The motor mount and bearing/servo holders are all alloy, completed with a nicely shaped and hand painted GRP canopy
    Price for the Kit is just £339 inc VAT rrp.
    MANUAL Download
    Rotor Diameter: ca.980mm (430mm main blades)
    Tail rotor diameter: ca.214mm
    Gear ratio: 9.83-12,64 :1: 4,69
    Lipos: 4S-8S (best 6S 2800mah 30C)
    Motor: 1400KV-1600KV /3026 type like Scorpion 3026-1400 (1600) or Kontronik Mini Pyro
    ESC : 80A Like Hobbywing Platinum 80A or Kontronik Jive
    Flybarless electronic : Mikado Mini V5,yRondo,Sookum SK720 or similars
    Servos: CCPM 3 x Midi Servo like Savöx 1350 or similars
    Tail Servo: Midi servo or Standard Servo
    Weight RTF: ca.1850g (6S)
    Over all lenght: 1185mm
    Overall hight: 267mm
    Also we have these handy fuel caps
    Pro Fuel Cap
    This machined from solid billet alloy is a super fuel bottle cap/fillerfor £19.99 fits a variety of 38mm bottle neck sizes like Cool Power, WildCat etc in 3 colours blue, red or silver.
    Cheers from - make sure you have a look at our site...
    www.rjx-hobby.co.uk
    Or "Like US!" on Facebook.... Go on!.
    Ryanair Voucher
    Do you like it ? plenty of reads
    www.rjx-hobby.co.uk
    Ryanair Voucher
      Errrm No
        Simon
        For another £46 you can have a T-Rex 500 with 3 cyclic servos, tail servo, blades, ESC, motor and gyro. It's even dearer than the Gaui X5. I also think the growing market is in the 550 size class rather than the 500 size. Let's also hope that the RJX ali is better than it is on the Xtreme 50!
        T-Rex 150 DFC
        T-Rex 700E DFC, 750MX, CC ICE 2 120 HV, 3xBLS351's, BLS251, CGY-750, SG Reactor X2, OptiPower, Edge 693SE
        DJI F450, Naza M V2 GPS, Zenmuse H3-2D, ImmersionRC Tx
        18 MZ
        ​JR DSX9
          Thanks for the comments so far - its nice to have feed back chaps, yes its not cheap but as we all know sometimes with the Align heli the radio gear/blades is not everybody's favourite some preffer to fit their fav servos etc and it gets swapped out - its aimed at the Mikado level, which equal in cost but mostly plastic , remember this is all alloy (Paul :0 ) but well see - thanks so far and please keep sending comments
          Simon
          www.rjx-hobby.co.uk
          Ryanair Voucher
            I like the way the servos mount to an ali subframe that holds the main bearings. Having the motor on top with a lower bearing block for the pinion is also nice (at least that's what it looks like from the empty frame).
            Although the bigger interest level has shifted to the 550 I think it's probably possible to get a lot of performance out of a 500 with the
            advantage of much lower costs for Lipos and chargers etc. I say this based on how useful the Trex 500 is IMHO and yet it's a bit
            heavier and not quite as elegant etc.
              600 money for a 500 heli dont think its gonna be a big hit !
                Manual Link so you can see the features in detail
                Download PDF
                www.rjx-hobby.co.uk
                Ryanair Voucher
                  £339 for a belt driven 500! It's still £74 dearer than a Mikado 400!
                  T-Rex 150 DFC
                  18 MZ
                  ​JR DSX9
                    Some prefer belts as they're cheap to repair & robust - But the Mikado still is all plastic...
                    www.rjx-hobby.co.uk
                    Ryanair Voucher
                      whilest this is true and the rjx 500 looks like a good bit of kit the logo range is deffo flavour of the month on this forum at the mo
                        What I'm saying is that for £339 it should be torque tube at least, as belt driven helis tend to be cheaper than torque tube driven ones.
                        It's a good job it isn't torque tube driven, as what would the price be then?
                        T-Rex 150 DFC
                        18 MZ
                        ​JR DSX9
                          If you haven't seen one, look at the way a T-Rex 450 Pro goes together.
                          On that the bearing blocks and servos really do come in and out as an assembly (though you'll probably need to tighten the servo mounting screws in situ), and the motor and mount can be removed without disturbing the gear alignment.
                          I think I much prefer that set-up.
                          Also, look at the RJX anti-rotation guide. It looks like it's on a single bolt !
                          Yes, it's th@ tw@ Scallyb@...
                            I assume the anti-rotation guide fits into a slot or something but it's hard to tell
                            in those photos.
                            Yeah, I recently got a 450 Sport and kinda wish I would have gone for the Pro
                            or one of the Beam E4s that were for sale on here. I have not yet done anything
                            with the Sport and I am still considering selling it and getting something else but
                            I'm also not flying 450s as much as I used to so still undecided.
                              Looks quite nice but certainly very pricey so I don't think sales will be great. Hey, you never know. Good luck anyway RJX.
                              RCHA Member
                              LFXproductions.co.uk
