Bearing Block Glue?!?!?
  • Bearing Block Glue?!?!?
    Hi All,
    What do you use to secure the bearings into the blocks? I heated the blocks from my x50 '09 to remove the worn bearings but they were held in with some kind of glue as oppose to the 'fit' of the block.
    Futaba 8FG (Left JR to go back to Futaba)
    2 x 700 - BeastX / OS 91 HZ
    1 x Velo 50 - BeastX / YS 56 SR
    500 ESP - BeastX
    600 CF BeastX - Hughes 500E Fuselage
    Red loctite.
    x 3
      Now that's a quick reply.
      Many Thanks
      500 ESP - BeastX
        Green loctite for me. Can't remember the product number but will find it later if you need to know. Don't need very much of it either.
        JR Vibe Fifty fb (YS56)
          Shoe goo, as suggested by Finless. Got mine from the US, ebay if I recall.
            Green bearing locker for me.
            RT38 RiteLok, or the green stuff that comes with Align kits, which I think is R48?
            | 3D Championship
              I've Zap-a Dap-a-Goo : Is that the same thing ?
              I've also Red and Green Loctite
              Blimey, spoiled for choice
              500 ESP - BeastX
                zap a dab a goo is the same, tend to use green locktite as you can heat old bearing and it comes out easier than trying to remove goo.
                2 x velocity 50's v-bar
                msh protos v-bar
                schluter helibaby.
                  Thanks for such quick replies Gents - Much Appreciated
                  500 ESP - BeastX
