ENV swashplate
I have an excessive amount of play between the two halves of my swash plate. Looking at the underside of the swash plate it looks as if you can tighten the ring that holds it all together.
Is this all i need to do or is there something else going on here?
The ring is stuck solid and i cant imagine that it has worked loose as ill need to get some heat on it to move it.
anyone had this happen and is it fixable or is a new swashplate needed?
cheers Tony
cheers Tony
