Rave BALLISTIC FSC design,manual,vids and more
  • Rave BALLISTIC FSC design,manual,vids and more
    Rave Ballistic FSO
    The long awaited special edition version
    of the popular Rave ENV 700.
    Features in addition to the standard ENV:
    - Electric Specific design
    - Sliding Battery Tray
    - Direct servo drive
    - Helical Main Gear (K1005 version)
    - Helical Steel Tail Gears (K1005 version)
    … and several other performance enhancements
    FAQ
    What is FSO?
    FSO is a special edition machine.
    It will be sold only on a "Factory Special Order” basis. We will work to fill the orders as quickly as possible.
    Do the FSO and the ENV share parts?
    Yes! These helis share a majority of the same parts and will be inter-changeable. That being said, all parts will remain in stock, ENV and Ballistic both.
    Will the Ballistic be available for a limited time only?
    No! The Ballistic is here to stay!
    What are the kit differences?
    The K1005 has helical cut main gears and has helical steel tail gears.
    The K1006 has the standard plastic gear set, identical to the ENV.
    Specs:
    Length: 1340mm
    Height: 420mm
    Main Blade Length: 690-710mm
    Main Rotor Diameter: 1,531-1,571mm
    Tail Blade Length: 105-110mm
    Tail Rotor Diameter: 294.5mm
    Main Gear: Helical 130 Tooth Mod 1
    Autorotation Tail Drive Gear: 118 Tooth Mod 1
    Tail Miter Gears: Steel Helical 19 Tooth Mod 1
    Also includes:
    Carbon Fiber Frames
    Painted Fiberglass Canopy
    Aluminum Tail Boom
    Steel Helical Tail Gears
    Helical Main Gear
    Carbon Tail Gear Box
    Boom Support Bridge
    Velcro Straps
    ESC Front/Top Mount
    Boom-Mounted Tail Servo
    Dual-Support Tail Control Arm
    Check it all out at;Curtis Youngblood :: Rave Ballistic
    Lovley manual;
    Ballistic FSO Manual Eng
    I WANT ONE!!!!!
    I want one too....
    Lynx Heli Team Pilot
      I read on another forum that the sliding lipo tray will not fit the ENV which is a real arse as it's my only real gripe that changing packs is fiddly and risky :-(
        I emailled Curtis a few weeks ago about this and there is going to be an ENV to Ballistic conversion kit coming out early next year. So should one of my Raves happen to do the frames in the I may end up with a Ballistic
          I wonder if Fastlads will be ordering them?
            Yes, I think they will be getting a small number of kits, but no firm date as yet
            Garry
            Logo690SX with Spirit System
            Logo550SE with Spirit System
