Rave ENV and Vbar, Swashplate/Control modifications from stock required?
  • Rave ENV and Vbar, Swashplate/Control modifications from stock required?
    Hi All, another ENV question, sorry!
    I've read from various sources that modifications are required to the stock ENV setup if you intend to use a Vbar for control.
    Generally it would appears that-
    1) Change the inner swash balls, the ones that go up to the blade grips, for 4mm stand off balls.
    2) Select a servo horn with 10mm centre to ball spacing and space the t arms balls to match
    3) Change the t-arm to swash ball link to the inner hole rather than the outer hole
    Is this correct? Is this how everyone with Vbar has their machine setup?
    I'll be on 140 degrees CCPM if it matters
    Matt
    Small point, but is it worth using 140 with a VBar?
    I seem to recall some suggestions that 140 was marginally better with a flybar but once flybarless 120 was the preferred solution.
      Not sure actually, i was always under the impression that 140 degrees was the preferred setup to 120 degrees due to less swash inter actions. So now that i finally have a heli (Rave ENV) and a transmitter (Dsx11) capable of supporting 140 degree CCPM i was going to utilise it, but this was all based on a flybarred machine.
      So, i've asked on the Vbar support forum if the Vbar is designed around a particular version and which i'm 'best' off using, and i'll go with their recommendation
      Matt
        These recommendations are also required when using a BeastX FBL unit too. And they work !!
        Garry
        Logo690SX with Spirit System
        Logo550SE with Spirit System
          Cheers everyone, i will setup accordingly
          Do you adjust the t arms for the 10mm servo wheels by drilling and remounting the balls. Or do you leave them at the default spacing on the t-arms and just not have parallel push pull pushrods?
          Any chance of a picture?
          Matt
            Anyone?
            Do you adjust the t arms for the 10mm servo wheels by drilling and remounting the balls. Or do you leave them at the default spacing on the t-arms (Approx 14mm) and just not have parallel push pull pushrods?
            Matt
              Hi matt. I used quick uk metal wheels at 10.5. 120 ccpm and inner holes on bell cranks.
              Worked perfect.
              James
              SEMAS Flying Club
                Decided in the end that i'd drill the t-arms to keep the arms pushrods parallel and servo travel linear at the 10.5mm centre to ball distance
                Can't wait to get it in the air!
                Matt
                  ...... which incidently didn't work, as when i have come to do the elevator t-arm this morning there is no meat to mount the balls at 10.5mm spacing without using standoff balls, which i haven't got.
                  So, back to stock t-handle spacing
                  Matt
                    Probably for the best anyway Matt because if you change the servo wheel diameter and also change the T-arm to match you haven't achieved any control throw reduction, which is the point of this isn't it?
                    Gaui NX7, Vbar Neo, OS 105. Rail 696
                    Logo 690SX v2, Vbar Neo, Edge 693
                    Logo 700, Vbar Neo, Tribunus 200, VTX 717
                      Matt
                      Just keep them standard and set the ball on your servo at 10.5mm.
                      James
                      SEMAS Flying Club
