Rave Ballistic Electric!!
  • Rave Ballistic Electric!!
ID:	1901691 Click image for larger version
ID:	1901692 Click image for larger version
    Early days, but pictures are starting to come out for the Electric Only Rave !
    Yes, I'm waiting for the Ballistic frames to come out so that I can convert my ENV electric. I've been told that there backwardly compatible.
    Garry
    Logo690SX with Spirit System
    Logo550SE with Spirit System
      I'm not sure we can depend on that being as simple as a straight swap.
      All we really know so far is that the Ballistic will use different frames and a lot of parts from the ENV, but last I heard there was no plan to produce an 'upgrade' kit so I'd expect that it might take more than just the frames to make the conversion.
      I'm sure we'll hear more before long though.
      Edit: Just found the original post from Brian : 'It shares 80% of its parts with the Rave ENV. Meaning the head, and tail are "basically" the same.' So expect to need a bit more than just the frames I'd say.
        looks good.im looking forward to seeing these
        cheers craig
          That's right, more than just frames needed but you will be able to convert with the right bits.
          It has a new resized canopy, direct CCPM servo layout is being tested and few other changes from the ENV to make it quite abit lighter.
