Rave ENV head block pins?
  • Rave ENV head block pins?
    Hi can u guys measure ur head block pins on the flybared rave because i dont seem to be getting much pitch without binding on the pins
    Adam Melton
    Synergy E7 : BeastX V3, Scorpion hk4525-520 LE, outrage HV servos
    ELYQ vision 90 : BeastX V3,YS91 3DS,Outrage HV servos
    Rave ENV: Vbar silver line, outrage HV servos, os105, hatori exhaust
    Trex 450 pro : Spartan quark, MKS ds95, scorpion hk 2221-6, 11t pinion
    Blade 130x !!
    Futaba 8fg
    Spin Blades / Rail blades
    Sponsored by
    About 35mm
    Glenn
    logo 600se
    700 N dfc
    700 dfc
      hi I am running a flybared Rave and get + & - 14 degrees without problem but if I push the stick in a corner I do get some binding on the pins at full pitch , but since I run a cyclic ring I have no problems.
      however WARNING you MUST remove the pins from the headblock , clean them and re loctite them in !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        that was only a problem with the early models
        Adam Melton
        Blade 130x !!
        Futaba 8fg
        Sponsored by
