Rave 90 env head speed
  • Rave 90 env head speed
    Hello everyone out their, just wondering what head speeds you lot are running on your raves with os105 HZ-r.
    idle up wise 1950, is properly nice, with 105 power.
    jonesheli or man will put you rite.
    Santander Factory Team
    Proud wearer of 5 x EGS
      Thanks mate
        +1 on Brian above. Run my ENV's wether YS120, OS105 or 91 powered around 1850/1900 in idle 1 and 1980/2050 in idle 2. Proper lively in idle 2 but also has bads of power at 1900.
        Just for your info though both my ENV's now have OS105 HZR's.
        George
        4x E
        GS
          rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
            now I cant remember the gear ratio of the Rave, but I have been flying the G4 raptor a lot and the one thing I found is that engine likes to rev, so I would go for 2050 rpmk on the head especially if you fly hard 3D
            good luck the Rave is a cool heli
              Here's the science, 15000rpm max torque, 8.12 gear ratio so 15000/8.12= 1847 now run it a bit higher so under load it sags in to the max torque so 1950 makes sense. Max rpm is 16500 so 2040rpm.
              MJ
                Also just wondered if the stock .02 mm shim is fine for opti 20%.
                  Stock shim is fine works well on mine and G's with Opti 20.
                  MJ
                    Thanks maj
