Scorpion HK -10 Failure?
  • Scorpion HK -10 Failure?
    Hi, has anyone had one of these motors fail? I've put approx 20 flights on the rave running the -10 with a CC 45HV esc (fully setup in gov mode) and 2200 4s revo packs.
    It was flying great with plenty of power and then the next flight the motor would not spool. It gives of a few squeaks and then stops and the ESC starts flashing. Messed around with the ESC settings but to no avail. Plugged in a -8 motor I had lying around to test and it spooled up fine.
    I've pulled the -10 motor apart but can't see anything obvious. Any ideas?
    Hi had that a couple of times on scorpion motor just switched throttle hold on and of and it was fine after that. Don't no why or if it's the same problem you have.
    Del
    Velocity 90 FBL Beast x
    Outrage velocity 50 nitro,
    Beam E4
    Futaba 10 CG
