fbl ball centres
  • fbl ball centres
    hey people, just befor i call it a night, just finished wiring in my velo90 to my cgy750, just wondered what servo centres, bell crank holes and blade grips hole people are running?? seems i could just run the servo exactly the same as before, but move the blade grips, or just leave the servo and move the bell cranks out a hole, or change the servos, was the highest resolution i can achieve, i know around the 50% swash value im looking for 8 degrees cyclics, but just wondered what u lot are running it and where?? cheers people
    no one???? ill just guess then lol
      nice to chat pete- for the record incase anyone finds this via a search- both my 90's run vbar full size and i use metal align horns with JR servos at 28mm for the balls, the bell cranks use the middle hole (also 28mm) and the middle hole on the blade grips.
        you to dude, cheers for the help, will have it all readyfor tomorrow now
