Converting FB head to FBL
  • Converting FB head to FBL
    I'm going FBL on my Velo 50 and rather than buying the whole head I'm going to convert my exciting FB head as some of the parts are the same. I've come up with these part that I need, can anyone who has done this confirm I've got all the right parts before I order them?
    R50N575-9 Linkage Rod Set FBL
    R50N575-4 Lower Mixing Arms FBL
    R50N575-3 Washout Base Set FBL
    R50N575-7 Blade Grip Arm Set FBL
    R50N575-1 Center Hub Set FBL
    R50N513-1 Swashplate Upper cup FBL
    Cheers.
    I've a feeling that drm black7 has all the parts to convert a velocity head, might be worth a pm
      Yep I've got them £30 posted If your interested.
      Gaui X7 Formula Vbar
      500 Pro Vbar
      Trex 450 L Dominator Vbar
      Oxy 3 Kbar
        Some picks, I don't have the swash upper plate, I just used the standard one.
        500 Pro Vbar
        Oxy 3 Kbar
          PM sent.
