Velocity N2 - Progress
  • Velocity N2 - Progress
    So after my shiney new N2 crashed 2 minutes into its maiden due to a servo arm breaking and then following a rush to get it repaired I managed to put the blade grips on back to front and stuck it in 30 secends into the 2nd attempt at a maiden I was starting to feel a bit disheartened.
    My club mate Thumb Rocker took pity on me, he took the heli away and spent the week repairing it and setting it up again so that we could go for the 3rd maiden this weekend. I was very cautious, checked absolutely everything, checked it again, spooled it up on the ground without take off for half a tank of fuel checking that everything was doing what it should then got it back on the bench and checked everything again.
    Because I'm convinced that I'm the jonah in all this I asked Thumb Rocker to do the first flight for me. No canopy this time and an old set of 600 blades cause we didnt want to take any chances, it took off, it did a couple of gentle circuits, it did a piro, it did a pitch pump, it did a pitch pump/piro and stripped the main gear!
    Still at least we got a about 90 seconds flying out of it this time and he managed to land without destroying it! I just dont know if that counts as progress or not?
    Guy
    And an E.G.S!
    Shame to hear mate. Outrage really need to sort out their main gears.
    Harry
    Powered by Futaba 18SZ
      Bad luck! I suppose it is progress as it didn't go in this time. You've got me thinking about maidens now (that's maiden flights, not the virtuous female type!) as I'm normally too excited to think straight and just want to get the heli in the air. Have you any idea what caused it to strip? Do you think it's a quality issue because I hear varying reports about Outrage's quality (normally favourable over the last year or so).
      Hope you get it sorted and get it flying as it should asap!!
      Goblin 380 - Vbar Control and Neo
      Goblin 570 - Spirit
      T-rex 700E DFC Pro - Spirit
        There's been lots about the TT gears stripping but not the main gear, I run all the black gears (TT, main & auto) and have not had a problem.
        Martyn
          I dont know, on my V2 I had the white gears and only ever stripped the TT ones if I crashed so they seemed pretty resiliant, Outrage then said that they were bringing out the black gears as an upgrade so I assumed they would be better quality on the N2. The meshing and backlash were spot on, Thumb Rocker checked it, I checked, and we all checked it after the strip by using the good side of the gear so it can only be a quality issue and not one of poor alignment.
          Ive been looking round other forums and no one else seems to be having problems so it might just be bad luck again!
          Guy
          And an E.G.S!
            Was the main gear the same one that had gone in twice before guy?
            Martin
            Aka RCSlopesurfer
              Yea but both times it went in I'd hit TH and it was checked pretty thoroughly before being re used. I guess that could be the problem but if you have to replace everything after a crash its not a very viable model.
              Guy
              And an E.G.S!
                I agree but I think that is probably your problem, good time to replace with the newer black ones.
                Martyn
                  Make sure you get the full set of black ones if you do, you can't mix the black and white gears.
                  Sent from my HTC Desire using Tapatalk
                  protos maxv2
                  TREX 700e DFC DOMINATOR
                  RC HELI NATION
                  CITIZEN NO
                  278
                    So long as the TT gears are all white or all black, it doesn't matter about the main and auto for mixing colours
                    Martyn
                      Is it the same pinion used on the maingear as before,only time i stripped gears was because of different sized pinions being used on the one gear.The only other time was a bad mesh(to lose).The black ones ive managed better pinion/maingear meshing
                        That's what I was told by climb-out and they are the uk distribution
                        protos maxv2
                        RC HELI NATION
                        CITIZEN NO
                        278
                          Are you saying Climb-out told you the front and back TT, main & auto gears all need to be the same colour ???
                          The Latest Fusion 50 kits (KR50F02) only come with black front & back TT gears, the main & auto gears are white and the black ones are optional, before I got the black main/auto gears I ran mine like this and it worked perfectly.
                          Martyn
                            Just to clear up any confusion, all the gears on my N2 are black, (when I spoke about white ones they were the ones on my V2) the one that stripped was black, and the one I have now replaced it with is black.
                            Guy
                            And an E.G.S!
                              as long as the TT gears are the same colour it will be fine, the auto and main are optional extras!!! check your pinion guy, you might of got a dodgey one!
