Kontroniks
  • Kontroniks
    Hi All,
    Can I use this
    Kontronik Jive 60+ HV Brushless ESC with BEC 4612
    on this set up
    Fusion 50 Flybarred
    Outrage 4125-560 on its way
    Undecided ESC
    Align DS610's on Cyclic
    Align DS650 on Tail
    Spartan Quark Clear Gyro
    Spektrum Ar9000 Receiver with Sat
    Undecided BEC
    2X Align 6S 3300 40C for 12S
    Spektrum DX7SE
    600 Size Blades
    Dave
    Hirobo Lama with Electric Conversion
    GraupnerMZ24 PRO
    Don't think it would on a 12S Fusion
    It's got continuous max of 60amps & think as a minimum you'd need something a bit beefier
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
      It's a pity coz the 80 HV is a little out of my price range.
      GraupnerMZ24 PRO
        Why not look at either :
        Scorpion Commander 130HV with SBEC : Scorpion Commander 50V 130 AMP 12-Cell Hv ESC (If you can get your hands on one)
        or
        even a Fusion Hawk 120HV Opto : Fusion P-FS-HWK120 - Hawk BL 120A OPTO N14~36/Li4~12
        or I have a Scorpion 90a HV Opto ESC i'm sellin (sorry for the plug)
        Dan
        Goblin 500
        Spektrum DX8
          I asked the same question on HF and they all said no because of the spike loads are higher then 100a.
          Sent from my iPhonings
          Oxy4+, tgy servos, hw60a, spirit fbl on 6s 🤓
          sigpic - Team pilot
            Remember 60A is minimum which it can provide, hence the +, on 12S my Logo 600 with 623mm blades and a Jive 80+ HV gets slightly warm if I give it a really hard flight. Granted I have a heatsink for the ESC. If you are flying hard a 60A might get a little bit too warm, but you should be able to fit a fan (jcooler JCooler 80 for the kontronic Jive 60/80/100 controllers jc80) and heatsink - the price will be 80HV territory then mind you.
