Velocity / Fusion owners, a quick favour please.
  • Velocity / Fusion owners, a quick favour please.
    Ive just got a new Velocity N2 and I'm not too happy with the fact that the canopy pushes on to 4 rubber gromets rather than the old way of thumb screws on the V2 & Fusion. My new canopy is already starting to crack from being forced on & off despite liberal amounts of grease and Ive only flown it a couple of times.
    So I'd rather go back to the old style screws & I'm thinking that I could fit the canopy stand offs from a Fusion or V2 but as they are in slightly different places on the frame I'm not sure they'll fit, so I wonder if someone could measure theirs for me. I'd like the distance from the break away tab to the end of both the front and back ones please.
    Guy
    And an E.G.S!
    They are :
    43mm rear
    30mm front
    Dan
    Goblin 500
    | Blade 130x | Blade 180cfx
    Spektrum DX8
    GWR Pilot 2011 & 2012
      my fusion is a push on type fitting, no thumb screws here, just make the holes a tad bigger dude
        They are really really tight, i'm going to have a look at mine as well to see if will be easy enough to make the holes slightly bigger
        Del
        Climb-Out
        3D Scotland
        Proud owner of 2 EGS
          I use these on my fusion.
          HERE
          The thumb screw stays in the cano grommit
            No problems here with the push on type, make sure to ca glue the inside of the canopy about an inch around the hole
            Martyn
              if your feeling flush you could purchase some quick uk magnetic canopy mounts. They work brilliantly on my 600 and 6hv and no more cracks
              Goblin 700
                Originally posted by danch View Post
                They are :
                43mm rear
                30mm front
                Cheers Dan thats perfect, I'll measure mine up in the morning and get some ordered up.
                I did try and reem them out a bit Pete but they seem like a much harder rubber than the older kits had on them so you get to a stage where they go on easy but dont feel like theyre going to stay on when the going gets tough!
                Guy
                And an E.G.S!
                  if you want a set of trex 700 QUK magnetic mounts to mod then hit me up, i have a brand new set here.
                    Yea I'll give them a go mate, let me know what you want for them.
                    Guy
                    And an E.G.S!
                      Hi
                      I had the same problem with my velo 90,i put align grommets(grey) in which are much softer and cheaply solved the problem for me.
                      regards
                        Canopy reamer!
                        Best tool I ever brought just don't over do it
                          sorry mate, i just thought as a last gasp i'd try them on my new e7 and what do you know, PERFECT fit.
                            Ha! No worries fella I'm not sure theyd work anyway because of the angle of the holes!
                            Guy
                            And an E.G.S!
                              if there is ANY angle they do not work. i tried to get them on my vel 90 but no go. thankfully it looks like the 30 quid was well spent now on the E7.
