Fusion tail servo arm length
  • Fusion tail servo arm length
    hi just wondering what is the optimal tail servo arm length to use? i'll be running 2100rpm ish.using 9256 tail servo, ar7200bx with 95mm tails.
    Hoping to get this thing test flown at the weekend I've forgot how long I've even had the thing lol
    cheers Lee
    Hi, if I remember right its 16.5mm from centre of servo horn to pivot ball, normally not too bad with the memory! I've got the velo50 so will be the same for Fusion buddy. Hope this helps.
    Dan
    Velo50, fbl head, AR7200bx, YS56sr, LiFe pack, JR8915, DS650
    600efl pro, beastx v3, Gryphon 7075lmt, ds610,ds650
    MCPX v1, microheli head n swash
    MD530 scale with Velo50 mechs, TGY1266HV, DS655, turnigy 3D-H,nav lights
      I also Have a velo 50 and its different because it goes through a bellcrank, on the fusion it direct off the servo....also my velo has a skookum on it so not really a good reference lol
      cheers Lee
        if your using 4 point horn, mines 2 hole in from outside
        Santander Factory Team
        Proud wearer of 5 x EGS
