which servo is which
  • which servo is which
    I have removed a 2.4 spektrum rx to put on my jr rs10ds 35mhz rx, I don't have 2.4 yet, which servo is which on the protos 500, has anyone a drawing or sketch what goes where?
    I hate this part!
    Plugging them in usually sorts things out. One at a time. Use a rx battery (4XAA) to avoid using the esc.
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      http://www.msheli.com/Manual/MSH_PRO...N_09_03_09.pdf
      Phoenix Sim
        The front servo is the elevator.
        The two rear servos are your pitch and aileron servos - it does not matter which way round these two are as you can adjust for it in your TX programming.
        I dont know what the port assignments are on your JR Rx but on the spektrum module servos go into the following ports
        Elevator servo - ELEV
        Pitch servo - AUX1 or AILE
        Aileron servo - AUX1 or AILE
        Velocity 50 (w/ Rossi R57) | Atom 500 | T Rex 450V2/Sport Hybrid
