good starting point for throttle and pitch curves please !
  • good starting point for throttle and pitch curves please !
    can somebody please give me a good starting point for curves on my 500 ! thanks currently using the ones of a earlier thread regarding a trex 500 but still doesent feel right
    Normal = 0-100
    Idle 1= 90 flatline
    Idle 2 = 100 flatline
    x 3
      Originally posted by sacko View Post
      Normal = 0-100
      Idle 1= 90 flatline
      This is a good base if you are not using your ESC in a governor mode.
      If you are using an ESC with a governor mode (stock Protos 500 one does have this option) then I would suggest allowing some head room for the ESC such as using 85% max, unless you really want the crazy headspeed.
      If you fly in normal mode you may or may not want to have a bit of a sharper throttle increase at the start of the curve, to stop the headspeed dropping when coming downwards.
        im getting somewhere with it now! just had a quick flight earlier and its noticeably better ! gonna have to put a bit of expo in methinks as its a lively little heli!lol
