Hi, I have a S9257 on my tail at the moment but want to upgrade to a better one as I'm getting a slight wag and heard that It could be the S9257. What servos do you guys use for the tail? Thanks.
Tail servo
is that on your MSH protos with the spartan DS760 gyro? I hate to state the obvious but have you tried changing the gyro gain much?
I don't have a MSH protos but I run an Align DS650 on my Raptor 50 and a DS520 on my Trex 500 which seem to work great. The align servos are good cause they can handle Higher voltages unlike a lot of the futaba tail servos which eliminates any problems you could get with a step down.Regards, Ross
Raptor 50 V2 - Quick UK shizz
T-Rex 500 ESP that looks like it's been Tango'd!
ma88ut is using a jr ds3500gChris 'CHUNK' Newby
ALIGN-TREX.CO.UK team pilot
LYNX team pilot
SPARTAN team pilot
Dx18
I've used an InoLab 261HB and a S9257 before I switched to a BLS251.
It really does make a difference. The tail is completely solid, and one of the best I've tried. It tracks like it's on rails.
With mini servos, there was always a wag and a slight twist on the tail.MSH Protos Carbon FBL Stretch- Scorpion 880Kv, YGE 80A, s9650 on cyclic, BLS251 on tail, Mikado V-Bar 5.1
MSH Protos Carbon FBL - Scorpion 880Kv, YGE 60A, s9650 on cyclic, BLS251 on tail, Mikado V-Bar 5.1
Multiplex Parkmaster
Ikarus EXTRema 330s
Yeah ive tried turning up the gain and turning it down but there still is a slight wag no matter what I do. I might try the BLS251 out.Originally posted by shikari_chaos View Postis that on your MSH protos with the spartan DS760 gyro? I hate to state the obvious but have you tried changing the gyro gain much?
One thing I tweaked on the spartan was the deceleration profile. It really helped a lot on the fast tail stops. No bounce now.Last edited by whisperdancer; 16-03-2010, 06:15 PM.MSH Protos Carbon FBL Stretch- Scorpion 880Kv, YGE 80A, s9650 on cyclic, BLS251 on tail, Mikado V-Bar 5.1
Ikarus EXTRema 330s
