swash wobble
  • swash wobble
    I have noticed a bad wobble on my newly built protos, it is the swash that is doing it and have seen a video from ecafinator on youtube showing exactly the same as mine.
    [ame]http://www.youtube.com/watch?v=OKg39UqQDks[/ame]
    I did spool the machine up but when i put a right aileron movement in it also pitches backwards onto the tail, my head geometry is as per the manual with all links checked for length and setup with +/- 12 degrees. Servos are Hitec HS5245MG.
    Help.
    Trex 700 LE
    Trex 600 LE
    Trex 450 Pro
    DSX 9
    www.midlandhelicopterclub.org.uk
    mine did that but after 2 flights it bedded in!
    andy
      what setup you running on your protos?
      Trex 700 LE
      Trex 600 LE
      Trex 450 Pro
      DSX 9
