So my protos was working fine a week ago when I decided to change the ESC out. I only removed the side frame to get access then put it back again and now when I spool up, I get such bad vibrations that it makes a loud grinding sound. When I hold it I can feel the vibrations and grinding but can't see anything wrong!
The belt is tight but not overly so, the main shaft feels smooth when rotating by hand, all pulleys are in place and the motor when run on its own sounds fine. The main gear appears a bit wobbly but its flown fine before with the same gear.
What can I check next? Does anyone recognise the sound? Its such a blatant noise I'm convinced its something obvious but no luck so far.
