Thinking of getting a logo 600 3d
  • Thinking of getting a logo 600 3d
    Hi guys,
    I'm thinking of getting a logo 600 3d.
    I'm after people's opinions on them and is parts readily available?
    Fastlad have a combo which is
    MIK2240 -LOGO 600 3D with Mini V VBar Kontronic motorset/rotorblades
    LOGO 600
    with VBar rotor head / VBar-Electronic
    Kontronic Pyro-JIVE Motorset / Rotorblades
    Specifications Helicopter
    Rotor diameter 1350 mm - 1450 mm
    Rotor blades 600/620 mm
    RTF weight ca. 3,4 kg
    recommended batterie 10S LiPo
    Main gear ratio 8,1 - 12.9
    Main Gear size 106 teeth Modul 1
    batterie slot 62 x 54 x 300 mm (HxWxL)
    Kit Content
    Kit Kit with VBar Rotor Head
    Accessories Antistatic Kabelset
    Manual detailed printed manual
    Motors Motor Kontronic Pyro 700-52
    Motor pinion Motor pinion Mod.1, 12 teeth
    ESC Kontronic Jive 80 HV
    Servos ---
    VBar electronic Mini V-Bar "Blueline" 5.0 Express
    Blades EDGE Carbon 603mm
    Tail Blades 85 mm Plastic
    Canopy Airbrushed Canopy
    Is this gear good? Iv never had a big electric so this is all new to me.
    Also what size packs do I use? Says 10s but it's that two 5s packs together if so what size mah
    Thanks Jon
    Jonathan
    trex 600
    Trex 450 v2
    and an
    Perfect heli choice,go for it if you have the money,10s is a good setup an I'd use two 5s 5000mah optipower packs for good flightimes.
      The spec you have above is very good. Yes 10s is usually made from 2 5s packs run in series although some manufacturers do provide a single 10s pack.
      P.s. you should buy the one I have in the for sale. Shameless pitch...
        Ok they are just awsome , why , i have no idea ,its all plastic (or some carlos fandango stuff) but boy does it fly well .
        I have used Total G and V bar in mine and they were both awsome its the most expensive airfix kit ever .
        no bling but wow does it fly well.
        Crash well ????????? no .
        enjoy
          Amazing heli, a lot of top UK pilots use them. I think they run them 12S mostly but maybe wrong.
          RCHA Member
          LFXproductions.co.uk
            Wonderfull birds, I love my Logo's. 5s batteries in series recommanded by Mikado and Dahl family Imho 5000 packs would be a bit heavy for the 600. 5 minutes light sport flying with my 600SE and I only put 2500 back in my TP 10s sticks. I could fly with 4000 mAh which are much lighter. Depends on your fliying style but something between 3200 and 4000 mAh should be fine for a light and powerfull 600 3D
            Mikado Logo 400/Kontronik Pyro 600-09/Kontronik Jive 80HV/Skookum SK540/3xS9650MG and MKS DS760/8s
            Goblin 630 incoming
              Parts are always easy to find, I love my Logo 600 V-Bar, still my favorite heli to own and fly.
              My setup:
              Mikado Logo 600 3D V-Bar
              Flybarless system: Mikado V-Bar Full Size
              ESC: Kontronik Jive 80+ HV with Kontronik heatsink
              Main blades: EDGE FBL 623mm
              Tail blades: EDGE 95mm
              Batteries: OPTIPOWER 3500mAh 6S lipo packs x2 (12S Flight Pack)
              Motor: Scorpion HKIII-4035-500kv 11T
              Tail servo: JR DS 8900G
              Cyclic servos: Futaba BLS 451′s
              Running on Spektrum DSMX
              12S = Slightly higher efficiency, lower battery and ESC temps.
              10 and 12S have the same RPM as you change the motor KV and/or gearing.
              10S still flys with the same power, and very nicely at that.
                Hi, I have been flying this setup for the last 5 mouths, its a very reliable setup with amazing performance :-)
                2 x 5s 4300mAh optipacks 6min 3D flights using about 3200mAh
                (also available from midland helicopters ;-)
                  Cheers everyone for your input.
                  Rach, they bad in crashes? What sort of common things does a crash usually take out other then normal boom main feathering shaft
                  Jonathan
                  trex 600
                  Trex 450 v2
                  and an
                    The main frame and main gear often suffer from crashes.
                    Goblin 630 incoming
                      I have seen 4 logo's go in, each time they were between £200-£300 providing all electrics are ok, this includes canopy, edge blade replacement and parts, i added my last crash up which came tp £274 on my 600 if i would have crashed a trex 600 same size it would have cost £342.36 plus links and bearings.
                      Main shaft £11.24 (get 2 of these)
                      vertical fin £8.99
                      Main thrust bearings £6.75
                      Complete tail assembly as it went in very hard £70.36
                      Main grips £26.09
                      Both side frames £72
                      Main gear £13.95
                      Boom £8.99 (get 2 of these)
                      main blades £65.00
                      tail blades £23.99
                      Canopy £35.00 canomod
                      Mainframe left LOGO 500/600 MIK4058 £21.74 Ordered: 1 £21.74
                      Mainframe right LOGO 500/600 MIK4057 £21.74 Ordered: 1 £21.74
                      Spindle shaft 86mm, steel MIK2347 £9.98 Ordered: 1 £9.98
                      Support for horizontal fin (tailboom dia. 25.0) (PAIR) MIK4096 £4.25 Ordered: 1 £4.25
                      Ball bearing flanged 5 x 13 x 4 (2) MIK3069 £5.24 Ordered: 1 £5.24
                      Ball Bearing 8 x 14 x 4 MIK2351 £5.44 Ordered: 1 £5.44
                      Thrust bearing 6x14 MIK2349 £8.50 Ordered: 1 £8.50
                      Blade holder 12 mm blade grip, incl. screws MIK2314 £8.50 Ordered: 1 £8.50
                      VERTICAL STABILIZER, CARBON LOGO 600 3D MIK4079 £16.50 Ordered: 1 £16.50
                      Carbon tail boom brace LOGO 600 3D MIK4097 £14.99 Ordered: 1 £14.99
                      Tailboom dia.25x755 mm, LOGO 600-3D MIK4098 £15.50 Ordered: 1 £15.50
                      Control rod 60mm MIK1586 £1.75 Ordered: 1 £1.75
                      Ball links 2.5 mm (10 pieces) MIK1565 £5.50 Ordered: 1 £5.50
                      Ball bearing 10 x 19 x 5 MIK1329 £5.50 Ordered: 1 £5.50
                      M3 X 10 NYLON BOLTS (10) MH-M3X10NYLON £1.99 Ordered: 1 £1.99
                      LINK ROD 2.5 X 65 SYN-107-065 £2.99 Ordered: 1 £2.99
                      Plus tail assembly £25
                      main blades £65.00
                      tail blades £23.99
                      Troll buster
                        Some people get upset when you talk about crash costs and how well they stand up in the event, but fact is they are not cheap to repair, not by any stretch of the imagination. Boom, skids, frames (if you havnt replaced the skid screws with nylon items), swash plate usually bends, easy to damage a tail belt, links are thin, and reasonably weak etc etc.
                        As long as you can accept that when the inevitable happens, you won't be in the realms of an Align's repair costs, then you won't be disappointed. My Logo 600 3D flew incredibly well, very smooth, quiet, powerful, and accurate, but I couldn't accept how fragile it was (and I wanted a 90, not a 50 - bought it as an SE, which was awful).
                          All bigger helis are expensive to repair. You just have to accept that the costs will be greater and factor that into your budgetting when you buy one! After all the likelihood is that you will have to repair it at some point.
                            Yeah but some are just more expensive for the sake of it! I feel the Logo 600 fits into the box nicely. I have no doubt that they are an amazing helicopter to fly, but cannot get my head round the repair costs.
                            SAB
                            Trex 500 FBL /
                            Beast X
                            Futaba 8FG
                            Proud Owner of 2 EGS Awards
                              Iv got an avant and a relatively light crash was £200 so used to high ish costs.
                              Jonathan
                              trex 600
                              Trex 450 v2
                              and an
