Will these paks be good enough for 600se?
  • Will these paks be good enough for 600se?
    Hi everyone,
    i'm considering to buy Logo 600se. As i have a lot of ZIPPY Flightmax 3000mAh 6S1P 40C packs from my other helis, i'm wondering if i can use those paks for Logo as well and what time flights i will have.
    Thank you...
    Zoran
    Simple answer is yes, but theres always an "however"
    3000mah on a stretch logo will make for an incredibly light setup. You may find real issues getting it to balance without having to either add weight to the nose, or have the front pack out so far its not supported well.
    Also, these packs on an already light machine will make it very "floaty". That may suit your style, it may not.
    Finally theres the issue of flight time.
    I would hazard a guess at about 3 to 3 1/2 minutes depending on headspeed.
    The (sort of) recognised norm is 3300 to 4000mah on a 12S standard logo, and 4000 to 4500mah on an SE.
    That being said, you have the packs already, so theres nothing really stopping you getting it flying on what you have and buying more suitable packs as and when you can justify it.
    Born to Fly, Forced to Work
