Has anyone else had the case come apart on there neo? Noticed my heli drifting and kicking the tail out and discovered the internals had come loose inside the casing. Theres no obvious fixing points like the screws that held the internals in place like you had on the blue/silverline vbars just looks like the top case snaps onto the bottom case with plastic lugs.
Whats holding the internals in place and are replacement cases available anywhere?
cheers Tony
cheers Tony
