Chase 360 - Head speeds for E-Gov?
  • Chase 360 - Head speeds for E-Gov?
    Hi
    I'm looking at setting up the Vortex E-Gov on the Chase and need some help.
    I currently run
    N = 75% flat
    Idle 1 = 90% flat
    Idle 2 = 95% flat
    But I need to turn these in to RPM and as the Chase is a 2 stage main drive I am not familiar on how to work out the main tooth count to use Mr Mels Head Speed Calc. Does any one know what tooth count to put in? All I know is the gear ratio which is 12.34:1.
    Rich
    SAB Goblin 700C - Black Nitro
    Flight Log
    THE MEDWAY MASSIVE
    WEBSITE FACEBOOK
    If you are using the Vortex e-gov you don't need any 3rd part calculators. The Vortex calculates everything it needs. You just need to set the gear ratio (see heli spec) and poles (see motor spec). As the instructions say you need to program approximate curves similar to a nitro. For example: N:0,50,100 1:100,60,100 2:100,60,100
    SPARTANRC - R&D
      Thanks Angelos.
      It's all set up on the Vortex E-Gov with 2700, 2850 and 3000rpm. All I can say is it was a very easy setup and it works perfectly. I am impressed and can't wait for the full release.
      Rich
      Flight Log
      THE MEDWAY MASSIVE
      WEBSITE FACEBOOK
