Having just set-up my first ebar on Nick Johnsons 5.5 wiring needs to be as follows on the Spektrum AR8000 using 1off DSM2 satellite (this need to be bound to your transmitter first). There is a 3 way lead that is included in the ebar kit, Aileron = White lead, Elevator = Red lead and Black goes to Rudder. The lead then plugs into the AER port on the ebar unit. Aux1 is your pitch channel which plugs into the ECR/Pitch channel on the ebar unit. Looking at the ebar unit the negative always goes on the bottom when plugging in. Power can then be fed into the ebar via the s-bus port , you will also need power going into the rx as well if you are running a rx pack (2s 7.4v). This can be done by making a split power supply lead.
