sensor placement vbar & tdr
  • sensor placement vbar & tdr
    Those of you that are using full size vbar mounted on your TDR, where do you place the main unit and the sensor? any pics would be great?
    Troll buster
    Heres mine Ross.
      Heres mine Ross.
      Cheers Ben, is that a custom shelf you have made?
      Troll buster
        No, it came with it. Rob installed it before and I forgot it was not standard kit until seeing your reply.
        Henseleit TDR Stacked V-Bar Mount
        If I did not have it I would mount the unit on its side against a side frame and have the sensor next to it flat on that back part. Does that make sense?
