Nope batteries are new only few flights old and does it with all 12 of them I suspect it's my motor or maybe I'm not at zero at mid stick so will check it out later today
Charles - Align 500EFL Pro - Blade 130x - Blade mCPx v2 - Spektrum DX6i & Phoenix Sim
don't see how not having 0 pitch at midstick would make any difference? i doubt a little to much positive pitch would cause that.
sounds like something wants ampage and it isn't getting what it needs, thats the usual reason for the kind of power problem your having, unless it is the motor thats on its ass.
I've checked battery leads and connections are sound to the 3 in 1, I've tried two other motors, a standard one and my brushless with the 550mAh batteries, still the same. I don't see how this can be anything other than the 3 in 1. Nothing looks to have obviously blown so its going back to HH next week, not going to start meddling with the soldering iron!
Looks like I fixed mine.... Pushrods were bent so replaced them last week turns out I was way off zero pitch at mid stick.... As soon as I levelled swash and sorted zero at mid stick no more probs.... Until I snapped my boom on first batt!!!! Glad I had a spare rod with me!!!
Just taken a look at mine (been flying the lad's recently!) and I think my main shaft is split as you can grab the head and gear and twist from side to side! Will replace it and see if that helps...
Neil
1 x
Raptor 30, OS32, on its way to being FBL (and leccy?)
Trex 450 Pro, Beastx, Savox 0257, DS520
Blade 180CFX DX9 & DX7
Too many planks...
