New MCPX V1, Weird noise...
  • New MCPX V1, Weird noise...
    New MCPX V1. All I did was take it out of the box, swap the board for a V2 board, put grommets on the swash and put a pre-prepared extended boom on it.
    Any ideas what this weird noise is? Doesnt seem to affect the way it flies at all...
    McpX weird noise... - YouTube
    TT Raptor G4 + Vbar
    just some hit and miss guesses bad motor bad main gear bad servo ?
      gah that sounds rough i'd be taking a look at the main motor.
        I'd guess either tail motor or main gear. Try holding it and giving left/right rudder. If it's tail motor it should get worse/better with left right rudder inputs. What's sort of state is the main gear in, do you have a spare to try? The main motor noise sounds fine but it has this extra intermittent noise on top.
          It's a dying main motor
            Its brand new,
            Like, literally - that was the first battery out of the box.
            I took the heli out of the box, changed only the carbon in the tail boom, put the V2 board on it and then test flew it. It made a funny noise, so I landed and made that video.
            The heli had had less than a minute flight time out of the box when I made that video. Flies beautifully actually!
            TT Raptor G4 + Vbar
              Hmm...
              Well that's the noise my main motor made when it was crapping out.
              You tried a drop of oil or two?
