MCPx v2 review
    Originally posted by Syclick View Post
    Not if you stick a 2mm x 6mm strip of gaffer tape over the end of the guides.
    I used a hot glue gun and put a tiny bit of glue over the ends.
    Sent from my LG-P920 using Tapatalk
      Vid now on first post. Need more practice at this sort of stuff for some work I got coming up.
      RCHA Member
      LFXproductions.co.uk
        lol,the end is funny
          Nice review dan!
          Adam Melton
          Synergy E7 : BeastX V3, Scorpion hk4525-520 LE, outrage HV servos
          ELYQ vision 90 : BeastX V3,YS91 3DS,Outrage HV servos
          Rave ENV: Vbar silver line, outrage HV servos, os105, hatori exhaust
          Trex 450 pro : Spartan quark, MKS ds95, scorpion hk 2221-6, 11t pinion
          Blade 130x !!
          Futaba 8fg
          Spin Blades / Rail blades
          Sponsored by
            Cheers, first time doing anything like this. Harder than I thought it would be. Got lots in mind for my next review, whatever that may be.
            Dan
            RCHA Member
              Hahaha was bored to tears until the end.
              Nice vid. Just a shame my screen is covered in orange squash after watching the last bit
              Lynx Heli Team Pilot
                TBH Pete I was bored too! Lol. Hence my "flip out".
                RCHA Member
                  I thought you'd forgotten IU for a minute at the end but then I realised you'd just crashed into a tree
                    nice vid as always mate, the HS does sound a lot higher than on my v1, maybe after about 80-90 flights mine is giving up. Is it so much better than the v1 that you would get a v2 if you already own a v1?
                    Sab Goblin 500
                    • #25
                      Thanks. If I already had the V1 then I would probably still get the v2. It does feel much more locked it and has the needed changes already done.
                      RCHA Member
                      • #26
                        Glad to see the back is doing ok
                        • #27
                          If you want a little pointer from someone in the game can I offer you this?
                          Look back at 00:20 to 03:10, the viewer is on the same frame for the whole time which means their attention is likely to waiver. If you get some footage of close ups on your hands, the packaging and a couple of wides of the room you can drop quick inserts in on your timeline during the edit to beak up the segment. Also while you were flying you could have locked off your camera at the end of the garden and just shot a few seconds looking back at you pretending to fly so you have something to cut in. Not only does it help draw the viewer in it also gives them a sense of the surroundings & envoronment.
                          Although I hate the show if you watch the location pieces on Top Gear their editors are very clever with their use of random inserts, sometimes static views of completely unrelated items shot in bad light or with a grainy effects keep popping up to keep you on your toes. (I guess they have had to perfect something to cover up the poor scripts & dreadful acting. Just sayin')
                          Its worth recording something like TG and taking notes of how many camera angles they use, how long they stay on any particular frame, how many cuts & inserts they use and how often, that way you can build a framework of how many angles you need before you start.
                          Guy
                          And an E.G.S!
                          • #28
                            Cheers Guy, very useful tips!
                            RCHA Member
                            • #29
                              When you bind the V2 don't you need to use the rudder stick (unlike the V1) ? That is certainly what I have read and I believe that the instruction manual has been amended to include this.
                              • #30
                                Thanking gate88's post because its the first time(in an mcpx thread) that i have seen him not moan about the little heli
                                This was me at the end of his post --> then this was me 10 seconds later -->
