Ive just orderded what i think is the correct brushless setup for my V2 but could someone just confirm that i have the correct stuff please.
HP05s + 9T Pinion
XP7 ESC + programming card
Steve converter
Stock Frame
120 tail mod (but unsure what length boom or blades)
I have spent the last 4 days looking how people are wiring up there setups . and looking at my V2 board mine seems different in the way you solder the yellow signal wire to the board (please correct me if im wrong)
So i was going to just use the yellow signal wire plugged into the main motor plug instead .
Also instead of soldering the ESC to the main board i was jsut going to solder the main board wire to the esc wires , Will this work or will i encounter some sort of problem.
Is anything else nedded to program the ESC because i dont have a Spektrum RX
To be honest i would rather not solder anything to the main board as the luck i have isnt that great at the moment.
If anyone could advise me then i would be greatful
Anthony
HP05s + 9T Pinion
Steve converter
Stock Frame
Anthony
"Getting Bigger By Being Better"
