So after a lil bit o squinting i upgraded my mcpx v1+ microheli carbon frames and +20mm on the tail, not enough power! so fitted the Hawk creation Hc-025 brushless motor and the Hc-o32 esc/converter without any problems (exept the eye's!) it flys ok but i'm a bit stumped with the Hc-032 esc set up, i have followed the set up instructions lol! but can't get rid of the inconsistant throttle in (normal) idle up is ok'ish at the described 60%. can anyone enlighten me as to the set up of this esc?
Sorted smooth as a virgins thigh! not that i can remember lol esc/converter needed programing properly lol. just as a note (excuse the punn) the stock mcpx motor wieghs 12g the Hawk Rc brushless motor Hc-025 is 4.2g and the Hawk RC esc Hc-032 is 2.4g do the math yourself! power to wieght ratio is markedly improved. + the nano tech batterys i've got comming should get quite a reasonable flight time now
cuppa
cuppa
