Hi all, first post so be gentle!
Purchased a mcpx v1 with DX4e yesterday. First proper heli (I know I should have chosen something easier) but I like a challenge.
Anyway, I've been trying to get the hang of it indoors and it was a nightmare; couldn't get it off the ground. Did a bit of research and checked pitch and found it had a lot of negative so I adjusted the servo linkages and now I have very little negative and a lot of positive (which I believe is required for beginners?) I have now managed to get it off the ground and can hover for a few seconds outside before I bin it into the grass! I will be getting a sim in a few weeks along with a dx6i as I understand that they will make things easier but could someone confirm this? The dx4e seems to be a bit pants if I'm honest as I've had to re bind a few times cause its flipped out!
Also will I need to turn the linkages back on the servos when I get the dx6i as I understand i will be able to set pitch etc digitally instead of mechanically as I have now (I think!).
I know it's probably going to take me a few weeks to get flying and I don't expect to be inverted in the living room anytime soon but any reassurances from you guys who have been there and got the t shirt would be much appreciated.
Cheers.
Cheers.
