FBL not working
  • FBL not working
    Hi all,
    I have been rebuilding and setting up my mcpx this morning and i have had nothing but problems.I changed the feathering shaft which was a bit bent.Started glueing broken canopy mounts.I also found a stripped servo gear which i have just replaced with MSR gears (seem to be the same)
    Anyway i did a swashplate setup (after tips on here) and all seems right.0 pitch at mid stick and level swashplate.
    So i spooled up and it hovered strangely.I corrected aileron left and it just flew off to the left like a bat out of hell.I turned the rates down thinking i must have been playing with settings previously but found it programmed as it should be.
    So i spooled up again and the same thing happened.I have now realised that the heli is not correcting itself.So if i put in left cyclic it just keeps going left.If you put in left/right cyclic while its on the ground it re-centres
    so the servos are doing as they should be but as soon as you spool up it seems like the FBL doesnt work.I picked the heli up and tilted it left and right and the swash doesnt counter the movement.Does that mean a knackered 3 in 1?
    P.S) I tried a re-bind but still doesnt work
    HK450GT Pro TT
    E-flite Blade CP Pro 2
    E-flite Blade Nano Cp-x
    E-flite Blade MSR
    Spektrum DX8
    E-flite Blade 180 CFX
    Phoenix sim
