picked up a mcpx today
    Look after the main frame. I think in few years a mint main frame will worth lot's of money.......hains teeth?
    sigpic X 2
      Zzzz. Try the brushless upgrade. Then you'll see!
      Steve
      Trex 500 ESP
      Trex 450 Pro
      Trex 250
      Blade 130 x (2)
      Brushless nano
        Originally posted by redbelly82 View Post
        ok job done where you get the longer booms from?
        Midlands Helicopters do 1 metre lentghs for a couple of squids or so. Midland Helicopters Ltd HeliSprs_BladeMCPX
        Trex 450 SEV2.
          is the carbon better than the aluminium?
            Carbon is plenty good enough.
              Well you can bend ali straight after you've twatted the deck, but carbon, she just break. Hobsons choice really.
              Trex 450 SEV2.
                cheers thanks for your help people
                  Really want a mcpx now...... onto fleabay i guess.......
                  http://www.rc-hero.co.uk
                    i only hear good things about them and i love mine wouldn't leave home without it lol,go for it just remember too get some spares.
                    • #25
                      That's cause anyone who tries to say bad things about them is hounded into submission!
                      Just sayin'!
                      Guy
                      And an E.G.S!
                      • #26
                        Just sayin'!
                        Lol, whatever it takes....
                        • #27
                          today fitted the alloy xl boom with a little carbon in the end.You need too do a little soldering on the plug to get it through the boom,the small bit of carbon that fits between the boom and helis is very fragile,i landed on the sofa a little hard but nothing to worry about and it broke,replace with a spare another little knock and broke again,the standard broken 1 with sticky tape to hold it together was much stronger.Now need too get more bits of carbon if i can find any in stock.verdict alloy boom wouldn't bother.
                          • #28
                            sorted the tail boom found that the little carbon bit that comes with the alloy boom are s**t so got a length of carbon and cut it to little bits,also did not drill the 2 little holes in because was a nice tight fit,its 100% stronger than the carbon you get with the boom and has not broke even after some heavy crashes.
                            • #29
                              Put a slit into a short piece of elastic band just long enough to fit over the main shaft and 2 linkage rods. Saves you keep loosing the rods.
                              TRex 500 FBL DFC VBar Pro Blueline, Standard Align Setup.
                              TRex 500 Pro DFC 3GX, Standard Align Setup
                              mCPX
                              Phoenix
                              Futaba 10C
                              • #30
                                A small blob of hot glue over the open end of the 2 forks works for me
