Going to buy the MCPX-BL
Huh, say what? That lead won't fit either the batteries or the charger?
These are the ports on that charger (the image is straight from the website linked to)
It's got standard banana plugs, plus JST-XH balance ports.
OP, the cable you linked to uses a JST plug, but that's a different connector to JST-XH, and won't connect directly to that charger. The adaptor cable above also doesn't fit, just look at the ends.
The easiest thing for you to buy would be the micro paraboard I linked earlier in the thread, it will plug straight into that charger and it includes fuses to protect your packs.
Micro Paraboard JST-PH / E-Flite UMX 6 x 2S 130X Etc Balance Board [UMXPARABOARD]
Electronics: Spartan VX1e / Spartan VX1n / Spartan VX1p / MSH Brain2 mini / Jeti DS-14
Sims: Realflight / AccuRC / Phoenix RC (Wireless) | AccuRC (Wireless) | Realflight (Wireless)
Hi. I'm sorry, I am totally confused now. I already double checked with someone before I made my main purchases that everything was correct, but now it's not?Originally posted by myxiplx View PostHuh, say what? That lead won't fit either the batteries or the charger?
[ATTACH=CONFIG]82115[/ATTACH]
[ATTACH=CONFIG]82114[/ATTACH]
This is the first time I have been told I need whatever that item is you have shown me. <edit > sorry, I must have missed the earlier link.
Please forgive my frustration, I just don't know what I've bought that is wrong; was it the banana plugless parallel lead or the cable I ordered at 2am last night? Or are both wrong?Last edited by 5hane; 29-04-2015, 08:43 AM.Blade® mSR XBlade® mSR
Spektrum DX6i
neXt sim
Shane, buying the wrong thing is all part of starting out - so don't let it get to you!
If you're looking to charge MSRX packs with your new charger then you will need the lead you posted earlier. But that comes with a red JST plug that won't plug into your charger - either get an adapter or snip it off and solder on some 4mm male bullets.
To to charge the mcpx 2s packs you will need the paraboard mentioned above.
PhilPhil
ok ... so hopefully to remove the confusion. The charger has two types of ports - the BALANCE ports (JST-XH) and the main power ports (BANANA)Originally posted by 5hane View PostHi. I'm sorry, I am totally confused now. I already double checked with someone before I made my main purchase that everything was the correct, but now it's not?
The parallel board for the 2S will plug straight in. The balance plug is JST-XH and the power plug is BANANA - all's good!
The parallel board for the 1S however has a JST (not JST-XH!) for the power connection rather than BANANA. The alternative board that myxiplx linked to does however have the correct combo of JST-XH and BANANA.
HOWEVER, he charger comes with cables that convert BANANA to XT-60. So the adapter cable that James_2k linked will convert XT-60 to JST allowing the 1S board you've bought to connect.
So you have a choice ...
1. Buy the JST <-> XT60 adapter and use the 1S board you've purchased.
2. Buy the alternative 1S board and no need for an adapter.
It's all very confusing!
So apologies, I didn't spot that originally, but as you can see it's not always simple and sometimes the web adverts aren't very clear! Either way, you're good to go with maybe a few quid extra.
for reference ...
JST : http://hangar18hobbies.com/images/connectors/jst.jpg [power connection ]
JST-XH : http://www.3dxhobbies.com/images/pro...20jst%20xh.jpg [ balance connection ]
Banana : http://image.made-in-china.com/2f0j0...s-Set-Four.jpg [ power connection ]
XT-60 : http://www.rc-electronic.com/images/.../A85066_01.jpg [ power connection ]
Final image which hopefully makes it clear how the board plugs into both the POWER and BALANCE ports on the charger. Hence why the 1S board you've purchased with a JST power connector will either need the converter cable, or you could replace with the board suggested by myxiplx
Ta, I think im ok now. I already have the correct 2s parallel lead ordered.Originally posted by philipjdall View PostShane, buying the wrong thing is all part of starting out - so don't let it get to you!
PhilBlade® mSR XBlade® mSR
Spektrum DX6i
neXt sim
Your all trying to help, so it's all goodOriginally posted by tomatwalden View Postok ... so hopefully to remove the confusion. The charger has two types of ports - the BALANCE ports (JST-XH) and the main power ports (BANANA)
for reference ...
Thank you for simplifying things and for the image references.
Ok, I already placed the order for the XT60 that James suggested at 2am, so I will stick with that as it will work then.
(James, I have faith in you, I was just thrown by the comment that it wouldn't fit
I guess at least I am learning
Can I just ask; when you say "parallel board" or "1s board", are you also referring to parallel lead? I am sure you but I just want to be certain.Last edited by 5hane; 29-04-2015, 09:44 AM.Blade® mSR XBlade® mSR
Spektrum DX6i
neXt sim
oh man, so much confusion, not being helped by certain people
cough-myxiplx-cough
anyway, if you bought
2 Pin 6 x Pico Plug Charging Set Eflite compatible. (UK Warehouse)
and
Q-LP-0036 Quantum XT-60 Female To JST Adapter 20awg Silicone 100mm Model Helicopters
then you are set for your msrx batteries, you use the cable that comes with the charger, as tom said.
Spektrum IX12
Blade Inductrix
T-Rex 150X
T-Rex 450L, Heli Option Turn-buckles, carbon push rod, 6s, Stock Electrics, Giant Power Lipos
Goblin 380 Kyle Stacy, 360mm, 6s, AR7210BX, Align 430m/525m @ 6.0v, Castle Talon 90, Scorpion 3020-1000, Optipower 2700 30c
Goblin 570 Carbon Red, Stretched to 600mm, Blackline 3D Blades, 12s, BD 3SX, Align 800/850 HV servos @ 8.0v Castle 120 Phoenix Edge HV, Scorpion, Thunderpower G8s
T-Rex 800e Pro DFC, Hobbywing 200A, 760x Head, BeastX
To be fair, the suggestion of a 1S board that didn't require an XT60 to JST adapter for the power connection was a fairly sound one. Having a 1S parallel board with banana plugs that goes straight into the charger reduces the number of electrical connections and arguably increases efficiency, removes risk and complication. But both should work.Tom
Whoops! Seems I missed the comments about the MSRX, I thought we were just talking about the mCPX BL. And I didn't see any adaptor cables listed for that charger which was why I didn't think the XT-60 would fit.Originally posted by james_2k View Postoh man, so much confusion, not being helped by certain people
cough-myxiplx-cough
Sorry for the confusion 5hane :-) Despite the chaos I think you're in good hands here :-D
And just to be clear, the parallel board I linked is for charging mCPX BL batteries which are 2S packs.Helis: Oxy 2 FE / Oxy 2 Sport / Protos 380 / Oxy 4 Max / Gaui X3 380mm
the board idea isn't bad, just the fact it was said the one i linked wouldn't work. don't be going talking about things like risk and such now though, that's all we need
and any efficiency drop will not even be measurable im sure. and its hardly complicated, its one connection thatr you can leave attatched to the rest of it.
and later if he so desired he could cut ff the connector and solder. but i like the flexibility which comes with having multiple leads with the same connector on.Spektrum IX12
Blade Inductrix
T-Rex 150X
I feel humbled to be getting help from the pro's. God knows how I'd get there I am on my own!
The stuff from Hobby king has arrived. Now waiting for the XT60, 1st class from Model Helicopters.Blade® mSR XBlade® mSR
Spektrum DX6i
neXt sim
No where near pro man. Just know this as I had to go through it myself not long ago
it's nice when stuff starts arriving!!Spektrum IX12
Blade Inductrix
T-Rex 150X
Yup, we've all been there. I only started two years ago and in the process of learning ordered a bunch of stuff with the wrong wires, or wrong connectors.
On the plus side I've got all the bits I could possibly need now
So most likely pointing out the obvious: Even though it's already been said before that 2s batteries for the MCPX-BL won't need balancing so much because of their low capacity, they will however still balance anyway because of that third wire.Originally posted by myxiplx View PostOn your 2S batteries for the mCPX BL you will see the leads actually have 3 wires. For convenience on those little packs they just have a single lead that works for everything
Is there a reason why other 2s packs and above don't have the 3 wires as standard thus saving time using a separate balancing cable?Last edited by 5hane; 29-04-2015, 02:25 PM.Blade® mSR XBlade® mSR
Spektrum DX6i
neXt sim
