just wondering the best way to charge battery for the mcpx bl? i use the supplied charger and its SLOW! i have a lipo charger, just wondering if its worth buying a banana plug adapter.
how do you charge your mcpx bl?
James - The supplied charger will only charge at 1C charge rate. Better chargers can do 2C and above, and can parallel-charge multiple batteries at the same time. For example, I usually para-charge 4 mcpx LIPOs in about 30-40 mins.
IC-W130XPAR | Parallel Balance Charge Lead - 6x JST-PH - Blade 130XLast edited by tomatwalden; 18-01-2014, 04:50 PM.Tom
Bear in mind, that's just the parallel charge lead. You'll need a proper charger to connect it to!Tom
i have one of these i used on my cars, i assume its ok?
HPI Racing Reactor 500 LiPo NiMH High Performance Battery Charger
Yeah - that should do it I think. It's only 50W mind, so it will struggle with multiple 450X batteries when you move onto that!
