Is there a 3 way mSR X battery charging in lead available
  • Is there a 3 way mSR X battery charging in lead available
    Hello all
    I have been looking to see if there is a 3 way charging lead that is available that charges batteries in series for the mSR X, or if there is a lead that charges in parallel i would consider that but i am not sure what the charging settings would be with one of those.
    Dave
    you could make up either a parallel or series lead easy enough.
    charging in series - you would charge @ 3s (11.1V) and at 1 times the mah of a single cell.
    charging in parallel - you would charge @ 1s (3.74V) and at 3 times the mah value of a single cell.
    WEA-TTI-TMFC........
      Originally posted by Davethepitch View Post
      Hello all
      Dave
      Hi Dave,
      You can get a 6 x pico adaptor from miniaviation that plugs directly into a B6 charger if you have one.I use one and it comes with instructions for use if you haven't charged in parallel before.
      Also, you can get a 6 x pico plug harness ,but if you want to connect that to the B6 you will need a further lead with a female JST- 4mm banana plugs. The harness is available in the UK but HK also do them,and you can either make up a 4mm-Female JST or buy one in the UK.
      DF
        assuming the msr battery connector is the same, looks like it, I think this is what you are looking for Skyline Models :: Batteries, Chargers & Accessories :: Battery / Charging...
        Sev
        Thunder Tiger E700 BD3SX
        Trex 450L DFC BD3SX
        Trex 150 PRO DFC
        Blade Nano CP X
        Blade mCP X v2
        Blade 130X
        DJI Inspire 1
        DJI Phantom 2 iOSDmini
        EMAX 250 Pro V2 FPV Racer
        Futaba 18MZ
        MK Heli Club MKMAA
        Proud Owner of:
          Hello all
          I purchased the 6 battery adapter from miniaviation.
          Dave
