Think I have fried the 3 in 1 on my cx2.Had a crash at full throttle.Now the light goes to red after 2 thirds throttle.Changed the motors,re binded to the tx but still the light goes red.All the shafts are straight and all bearings where changed just before the crash.Even with the system stripped down to bare motors I have the red light.Have I fried the 3 in 1?Or is there a way of resetting?Its the type thats stuck to the 6100 rx.
Fried 3 in 1 mixer?
The light goes red at 2/3 throttle - is that while you are actually flying or just messing on the deck?Originally posted by blade77 View PostThink I have fried the 3 in 1 on my cx2.Had a crash at full throttle.Now the light goes to red after 2 thirds throttle.Changed the motors,re binded to the tx but still the light goes red.All the shafts are straight and all bearings where changed just before the crash.Even with the system stripped down to bare motors I have the red light.Have I fried the 3 in 1?Or is there a way of resetting?Its the type thats stuck to the 6100 rx.
Are you getting normal/any flight, but just with the addition of the red light?
Are all other control functions kaput or are they working?mCX CX2 mSR
Blade 400
1962 Triumph 6T Thunderbird
BMW K1100 LTSE
Increasing overdraft
"Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Update
Sorry guys but I didnt get an alert to say my post had been replied to.
The heli was only lifting of the ground briefly then the light would come on and loose power and have to land.
I ordered a new 3 in 1.Connected it up tonight and no good the same thing happens,I have disconnected all the gears from the motors to ensure no binding but same thing.I have even disconnected the motors and same thing.I now think it may be the RX.I may have damaged it inthe crash,so now I am going to order a ar6100.I may have well have just bought a new heli
I am missing my flights round the house
Good move - they are certainly the ones to help.Originally posted by blade77 View PostHave emailed fastlads with the problem to see what they say
Daft question though - but are you certain that your battery isn't playing up?
Red light and no power is typical behaviour on my machine when I've been messing around on and off the workbench and not realised I've taken the battery to the point of need of a recharge.
A couple of times now, I've been cursing until it dawned on me what I'd done.
Doh!
Roger.
mCX CX2 mSR
Blade 400
BMW K1100 LTSE
Well, you've certainly covered the investigation in a logical way - and that seems to suggest your fear of extra expenditure may be realised.Originally posted by blade77 View PostI wish it was the battery.I have four of them all fully charged and no problems before the crash
My commiserations.
It's amazing how quickly the spares box grows containing the still serviceable bits bought trying to sort problems on these little buggers out eh?
I wish I owned a slice of E-Flite.
Roger.mCX CX2 mSR
Blade 400
BMW K1100 LTSE
Honestly not sure how it could possibly be an rx fault. Try plugging another servo into the throttle channel and see if it moves all the way through it's normal range if so then there's nothing amiss in the rx.
I'd be tempted to check that nothing is binding or sticking or causing any undue friction in the drivetrain also check your batteries are ok. I'd guess it's more to do with something causing an unduly high current draw.sigpicX2
