Blade 450 3d
  • Blade 450 3d
    Does anyone know were can get a manual or settings for 450 3d , tx is dx7s
    thanks for help
    Raptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
    hitec eclipse pro 7 tx with optima receivers
    Blade 130x with lynx upgrades
    raptor 90 under construction
    You go to horizon hobby site and download the manual
      Blade 450 3D RTF (BLH1600) Manuals, Parts Explosions, Team Tips, Bulletins and other Support Information: Blade - #1 By Design
        Thanks for help, is there a reason it runs wooden blades or can you swop them for others ?
          they use wooden blades because there cheap to replace no other reason most 325mm blades will fit be it carbon or wood
          walkera 4#3a full brushless
          walkera 4g3 soon to be brushless
            As already stated, you can run others but make sure you get flybar blades rather than flybarless. Flybarless blades are weighted differently. It won't make a big difference, but worth noting.
              You'll need (from memory) either 2 x.075mm washers or 1 x 1.5mm washer (nylon) when going for carbon blades.
              Worth the money IMHO, heli flies sooooooooo much nicer with carbon blades; treated mine to a set of revolutions after the recent rebuild.
              Cuffley MFC www.cuffleymfc.co.uk
              Too many toys to list...
