Please help blade 400 too tame
  • Please help blade 400 too tame
    Hi Please could anyone help with my settings. my mcpx flys very well and is very responsive. For the first time today i took out my blade 400 but it is very tame in responce its seems like it takes a minute to catch up with my stick input and i gathered it is adjusted in d/r&expo on my dx6i .
    my 400 is set to
    aile 100% + 30%
    elev 100% + 30%
    rudd 100% + 30%
    my mcpx is set to
    aile 70 % + 30%
    elev 100% + inh
    rudd 100% + inh
    Can i set my 400 to these settings , or is it too much and what is INH
    Any help would be appreciated.
    Sean.
    That looks like you have no expo set on the 'INH' controls.
    As for making it a bit more lively, you can always increase your ATVs! That'll make it flip and roll nicely
    Basically leave your DRs alone and increase your ATVs or End Points on uour aileron and elevator from 100% to something like 110%. See if that's make it fast enough. If not, crank it up some more. Also worth checking that your end points are in fact already at 100%.
    SAB
    Trex 500 FBL /
    Beast X
    Futaba 8FG
    Proud Owner of 2 EGS Awards
      but will it be ok to set my blade up with those settings of no expo or will it be too much.
      sean.
        sean.
        If you're used to using expo then add it in
        I personally don't use much expo, and I've only used it recently. 30% seems high. I'd drop that to 20% and see how it feels
        SAB
        Trex 500 FBL /
        Beast X
        Futaba 8FG
          drop the expo on airl' and elv to 10%
          increase the swash mix values by 10%
            my swash mix is aile -75
            elev -75
            pitch + 70
            so what shal i make them now. and what will this do.
            Thanks Sean.
              it will increase the movement available. Yours are actually quite high already so after you've added 10% just move the controls in all directions and make sure your not binding the servos at their extremes.
              -85%
              -85%
              +80%
              bear in mind Sean the blade will never feel as lively as an mcpx it simply doesn't have the power to weight
                and what is INH as this is what my mcpx is set to. See top post.
                Sean
                  basicly means its turned off. or zero......inhibited
                    Thank you Boggy for your help & time i will try these settings you have suggested.
                    Regards
                    Sean.
