Problem starting up Blade 450 3D
  • Problem starting up Blade 450 3D
    After a very gentle crash the other day (it simply fell over blades spinning slowly) I charged the battery for my Blade 450 and connected it to the heli. I turned on my DX6i which shows the blade 450 configured then connected the battery cable. The G210 lights flash red for a few seconds then remain red. No beeps from the heli and they don't go green. I can hear the motors whirring quietly but the heli does not respond to any commands. I have all switches on the DX6i set to 0.
    I'm a total n00b with the 450 so I'm probably missing something pretty obvious.
    try setting the throttle trim to the very bottom?
      Thanks. Just tried it but no joy.
        On your TX set Throttle to 0.
        Best thing to do is rebind! you will find this in the manual. DON'T forget to take out the Bind plug after binding.
        switch off. Then turn on TX then plug in the Battery.
        EVO 180
        MCPX
        Storm 400 rebuilt again!
        KDS 450
        Mini Titan V2
        DJI Phantom fc
        Big Steve
          That did it. Thanks a bunch.
