weird response
  • weird response
    When I move my elevator up and down on my transmitter, my main rotor spins.Anyone know what is happening here?
    Either Transmitter is set wrong MODE or you have plugged esc into elevator channel & elevator into Thottle channel on receiver.
      Everything is plugged in correctly.I fly all the time and heli is quite stable, just the main rotors spin when I move the elevator up and down.If I move it rapidly it will spin quite fast,something must be catching.I think its the elevator bell crank.It is a Blade 400 heli.Mode is also correct.
        You didn't say what tx you are using, do you have a mix turned on? I know some of the older tx's had an acc that increased throttle when a cyclic command was used.
        Cheers Daren
        Sponsored by Quick UK
        CLICK
          Hi I fly a Blade400, are you saying that by moving the elevator you are able to mechanically move the main blades around, or are you saying that the ESC is firing up and the motor is spinning the blades around?
          A video might help
            By moving elevator on my blade 400 the main rotors spin mechanically not through the esc.It does this with the throttle hold on.I move the elevator up and down and main rotor spins.The faster I move the elevator the faster the blades spin.I'm thinking its some interaction between the elevator bellcrank and the tail.I'm using a brand new e6110 spektrum receiver.I dont have a camera to make a video, unfortunately.No mixes are on in transmitter.
