Pitch curves and how they relate to pitch angle -- another noob question
  • Pitch curves and how they relate to pitch angle -- another noob question
    Still trying to get my head around head speed, throttle and pitch curves.
    On the DX6i pitch curves are given in percentages but how do these percentages relate to the actual pitch angle of the rotors. Is there a simple formula for this. How do I know that a given percentage gives me either a positive or negative pitch angle?
    Martin
    Never happy, merely less depressed.
    Blade mSR
    Blade 400
    Supercub LP
    Sukhoi SU-26
    Yanagisawa Tenor Sax (doesn't fly well though)
    Setup: Pitch Settings
    Throttle & Pitch Curves Explained
      The basic rule is that centre stick, pitch curve at 50% should give you Zero pitch, anything above 50% is positive and below is negative. This is on the basis that everything is mechanically and electronically level. I am running -11 degrees at 0% and +11 degress at 100%
      Gavin
      • Thunder Tiger Raptor G4 FBL - OS105 HZ-R, Bavarian Demon 3SX, MKS HBL HV Servos, Reactor HVX, Optifuel SLV 25%
      • Thunder Tiger Raptor E720 FBL. Bavarian Demon 3X, (Under Construction)
      • Gaui X7 - (Under Construction)
      • Synergy N5CTT - OS55 HZ-R, Bavarian Demon 3X, (Under Construction)
      • Gaui X5 Formula - XNova 4025-1100, Castle Talon 120HV ESC, Bavarian Demon 3X, MKS BLS Servos, Spin Black Belts, Optipower 6S 4300's
      • KDS Agile 5.5 - XNova 4025-1100 Motor, Castle Talon 120HV ESC, Rail 556's, Optipower 6S 5000 Ultras
      • JR Vibe 50 FBL Nitro (Retired!)
      Optifuel * Bavarian Demon * MKS Servo Tech * Optipower
      http://www.kaos-rc.co.uk
