EFLH1144 Head Dampening Shims
  • EFLH1144 Head Dampening Shims
    Does anyone know of any place on the interwebs that has these in stock? I've tried some of the obvious places but can't find any. Fecking feathering shaft sheared completely in half and spilt these into long grass
    I had 4 on each side and thankfully one side stayed on the shaft. Could I get away with 2 shims on each side until replacements come back in stock?
    I didnt have any.
    I have read that some came with them and some dont.
    Even on the Repairblade400 website, he doesnt have them
    http://www.repairblade400.com/
    x 3
      you can run whatever number you like as long its the same number either side and you dont have slop in your head
      Nik.
      Before you ask:
      About 2 miles
      Over £500
      Very difficult
      Over 80mph
      NO, you can't have a go
      Don't forget the 'Search' and 'Thanks' buttons.
      RIP Anthony 'Tinny' Lombardi (25195517)
        early blades had 2 on each side later ones have 4
        if you only have enough shims for 2 on each side try making some damper rings out of fuel tubing just cut them slightly thicker
          What is the point of the shims anyway? They are super thin and even 4 of them doesn't take up much space.
            they take up just enough room to take the excess play out of your head, i think they measure at 0.005mm or something stupid like that, take them out and you will notice a difference
            Nik.
            Before you ask:
            About 2 miles
            Over £500
            Very difficult
            Over 80mph
